Hello Guest it is October 22, 2026, 10:49:20 PM
Author Topic: should i use Win 2000 or XP for Mach 3 (newby to Mach... question)  (Read 9809 times)
iNOTaRobot
Well hi all,
I have just downloaded these excellent programs (mill and turn) and am going to try and implement them on my lathes and drill/jig borer.
I have quite a few older Pentium PC that are capable of running Win2000 but not XP.
As yet, I haven't seen any post or comments in the FAQ or elsewhere, re ARTSOFT preference or even when support for - upgrades to the Win2000 usable will cease.
As far as I can tell neither program is Operating system version specific.. But how about the plugins that are being offered and wizards ?
Maybe the G-Rex could be the way to go. If I am correct it is simply an embedded computer PCB that stands alone; and one that you down load G code program developed under mill or turn into. So one only needs one PC and a G Rex for each machine tool.
Mind you here in Australia, like most major counties i don't doubt, there are many second hand PC available for near nothing, that are often barely a year old. So this would be my preference as I could have one at each of my 2 lathes and another other at drill/jig borer.
Which raises another question about licences. Do I need licences for each lathe application or is there a home SITE licence.
1. My big lathe was made in 1905 in the UK and has a 2" clearance hole in spindle about 1.5 ton in all, totallyl manual operation.
2. My small late is a Southbend 9" bench lathe with quick change gear box on saddle/lead screw.
3.The Jig borer was made in 1953 and has a table movement of 24 inch (X) by 36 inch (Y) and a quill clearance of 24 inch and 14 inch (z axis) in two stages. It weighs over 6 ton currently has the original brushed DC motor BUT and a new full Quadrent Regenerative speed controller fitted.
Both it and the 2 lathes will present some challenges to automate, especially with the manual change gearboxes and belt drives installed. Sure I could bypass gearboxes/ stepped pullies and fit a more powerful motor but it rases issues of torque on shafts etc. I think one has to look at how to machine using, say back gears as one part of job then stop and manually de-engage same. BUT these sort of issues may have been discussed  in another forum that i have not yet read.
regards
David
Australia.
Re: should i use Win 2000 or XP for Mach 3 (newby to Mach... question)
« Reply #1 on: October 31, 2006, 09:43:44 PM »
Hello David,
    Check out thread XP vs 2000 on page 2. Not much, but may be of some use.
