Hello Guest it is October 20, 2026, 11:53:08 PM
Author Topic: Windows 7 Installation Problems  (Read 8322 times)
« on: October 21, 2010, 01:28:56 PM »
Trying to install Mach on a 32-bit Windows 7 system.  It has issues.
First, when trying to install, I get error boxes that say "Remove Program for Windows 2000 Drivers has stopped working".  I hit the "Click Online" choice and it seems to find a solution.  This happens several times.
The next ones are for:
ms8runtime.exe has stopped working
Mach3 PlugIn Control has stopped working
Mach3XML.exe has stopped working
They seem to clear when I hit "Click Online for a solution"
Next up is Parallel Port Drivers, and I get "Install Program for Windows 2000 Drivers has stopped working".  It goes back to "Installing Parallel Port Driver" and sits there.  If I open the Task Manager and turn off the Driver Test, I get a box that says "Installation Successful"
But, I don't think it works at all.
Any ideas out there?  I don't recall having any of this when I loaded Mach on a Win 7 64-bit laptop.
