Hello Guest it is November 04, 2026, 02:10:37 AM
Author Topic: G Code to set mach into reset at end of program??  (Read 14057 times)
« on: October 15, 2010, 09:53:22 AM »
Hi
I am after a G code that I can put at the end of a program to set Mach into the reset mode.
The reasoning behind the request is when in reset my drive boards power down and will keep the motors cool while sat doing nothing
I can then press reset when I run the next program to bring the boards back on line ready to run
Thanks in anticipation
Ex Apprentice
  •  9,375 9,375
Re: G Code to set mach into reset at end of program??
« Reply #1 on: October 15, 2010, 10:48:10 AM »
You could try........
Under 'Config / General Config' check the box 'E-Stop the system' on 'Pgm End or M30...'
Then make sure your programs all end with M30 (most do anyway).
« Reply #2 on: October 15, 2010, 10:54:54 AM »
Tweakie
Thank you, thought I had seen it somewhere when stumbling around
Ex apprentice
