Hello Guest it is November 11, 2026, 08:18:52 PM
Author Topic: Horizontal slider DRO format string ?  (Read 26671 times)
Offline tmead
  •  62 62
« on: October 15, 2010, 05:28:12 AM »
Anybody able to help out with the format of the DRO string ?
I've picked up that 'H' is the high limit, 'L' is the low limit and 'D' also shows the value and there must be a number format on the end to make it work. Anybody know what the other letters mean ?
Tim
Offline tmead
  •  62 62
Re: Slider DRO format string ?
« Reply #1 on: October 15, 2010, 10:50:15 AM »
OK, so it's now clear that sliders can't be horizontal, but this info would help with a vertical one !
Tim
Re: Horizontal slider DRO format string ?
« Reply #2 on: October 15, 2010, 11:01:34 AM »
Hi Tim,
actually, you don't have to bother about the format parameters. When you insert a slider you can select/set all the parameters in the property box.
Display pos : yes/No
Value pos  : top/bottom
Min : minum value
Max : maximum value
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline tmead
  •  62 62
« Reply #3 on: November 07, 2010, 09:29:26 AM »
Thanks Klaus, now I'm using your editor this is all much easier !
Tim
« Reply #4 on: November 07, 2010, 09:42:41 AM »
SL10H200%0.0f
S = Slider?
L=Low
H= High
%0.0F is the numeric format
This is for a slider that goes from 10 to 200 with 0 decimal places.
Offline tmead
  •  62 62
« Reply #5 on: November 11, 2010, 05:55:19 AM »
Thanks Gerry.
