Hello Guest it is November 22, 2026, 02:03:01 PM
Author Topic: Tooling Offsets using the Tormach method  (Read 33629 times)
« on: October 11, 2010, 05:25:45 PM »
Hi
Video Address:  http://www.youtube.com/watch?v=_8apTgMTvjI&playnext=1&videos=srC9h9H00Ps&feature=mfu_in_order
I have  tooling holders by Tormach that I`m using in my DIY router. I have gone over
the details of tool offsets in the above video. At this time I do not have the Tomach dial indicator
mounted in a holder. As a substitute I used a long drill bit mounted in a holder.
I setup tool 1 i.e. a long drill bit as the datum tool. It was placed on 123 blocks.
I brought the spindle down to the top of the 123 block and set in Mach3 that point
as zero.
I then found the top of tool1 and got a measurement of 5.2766
Tool2= 5.2356
Tool3=4.3434
Tool4=2.2066
Tool5=4.1271
I then loaded my code into Mach3 and brought T1 down to the surface of the part.
I set xyz to 0.000
I manually moved the machine from the part to allow for a manual tool change.
I placed T2 in the spindle and ran the program.
Problem: Tool2 raised extremely high over the work surface triggering my Z limit.
I have no idea why the second tool raised so high when it was a bit shorter the T1
I have a clearance plane set for .2 above the surface. Still the tool seems to be moving
just too high.
G17 G20 G40 G54 G64 G90 G43
(Spot Bearing Center Using 11/32 Drill Tool2)
T2 M6
G43H2
(0.34375)
G01 X-0.8000 Y1.3750 Z0.2000 F8.0
G81 X-0.8000 Y1.3750 Z-0.1 R0.2 F5.0
G80
G01 Z0.2000 F5.0
(Spot All Holes On Face Using 11/32 Drill Tool2)
G43H2
X-1.2336 Y0.7082 F10.0
G81 X-1.2336 Y0.7082 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
G81 X-0.8000 Y0.4000 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
G81 X-0.3664 Y0.7082 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
G81 X-0.3664 Y2.0418 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
G81 X-0.8000 Y2.3500 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
G81 X-1.2336 Y2.0418 Z-0.1332 R0.3 F5.0
G80
G01 Z0.2000 F5.0
(11/32 Drill Mounting and Bearing Tool2)
G43H2
X-0.8000 Y2.3500 F8.0
G83 X-0.8000 Y2.3500 Z-1.2 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
G83 X-0.8000 Y0.4000 Z-1.2 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
G83 X-0.8000 Y1.3750 Z-1.2 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
(Drill 5/32 for 10-24 Bolt Tool3)
T3 M6
G43H3
(0.15)
X-1.2336 Y0.7082 F8.0
G83 X-1.2336 Y0.7082 Z-0.7 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
G83 X-0.3664 Y0.7082 Z-0.7 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
G83 X-0.3664 Y2.0418 Z-0.7 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
G83 X-1.2336 Y2.0418 Z-0.7 R0.1 F5.0 Q0.2
G80
G01 Z0.2000 F5.0
(DrillTool 1.00 V End Mill Tool4)
T4 M6
G43H4
(0.875)
X-0.8000 Y1.3750 F8.0
G83 X-0.8000 Y1.3750 Z-1.5026 R0.3 F3.0 Q0.1
G80
G01 Z0.2000 F3.0
(Step Drill Custom Bit Bearing Hole Tool5)
T5 M6
G43H5
(0.9)
F8.0
G83 X-0.8000 Y1.3750 Z-1.25 R0.1 F3.0 Q0.1
G80
G01 Z0.2000 F3.0
M05
M30
Re: Tooling Offsets using the Tormach method
« Reply #1 on: October 11, 2010, 05:28:40 PM »
Do you have the safe Z enabled and set up as an incremental move?
« Reply #2 on: October 11, 2010, 05:33:17 PM »
Hi Hood
Don`t know I`ll have to check at the shop tomorrow.
« Reply #3 on: October 12, 2010, 05:27:12 AM »
Safe Z is not enabled. Still looking for answers
« Reply #4 on: October 12, 2010, 06:12:57 AM »
Can you attach your xml and also the Tools1.dat that you will find in you profiles macro folder.
« Reply #5 on: October 12, 2010, 07:38:44 AM »
Hi
Here they are. I didn`t find any tool.dat files in the macro folder but did in C: Mach3 main folder.
I hope I attached the right file.
Barry
Is my G code wrong
« Reply #6 on: October 12, 2010, 09:01:22 AM »
Hi
I got a email from Tormach. They mention to call a tool changes as follows: T2 M6 G43 H2.
I have T2 M6 and G43H2 on separate lines. At the beginning of Tormach code they have a
G28. I do not. Are any of these differences causing the problem.
http://www.youtube.com/watch?v=0cM32grBMvo&playnext=1&videos=zZR3HEjtfQU&feature=mfu_in_order
« Reply #7 on: October 12, 2010, 09:32:02 AM »
Barry the tools.dat file you uploaded is empty
It will be in the folder
C:\Mach3\macros\2008InchSlowSpeed
New File Upload
« Reply #8 on: October 12, 2010, 10:09:22 AM »
Sorry. Here it is
« Reply #9 on: October 12, 2010, 10:40:59 AM »
Just a thought , If the master tool (drill bit ) is the longest tool then all the rest will be - numbers when doing the measurement.  If you put in + values then mach thinks they are longer and raises the spindle??
