Hello Guest it is November 08, 2026, 03:10:00 AM
Author Topic: Inaccurate Dimensions  (Read 9574 times)
« on: October 09, 2010, 11:38:31 PM »
I use Rhino4 for creating a DXF, cut2d for creating gcode and mach3 for cutting the pattern.  Circles i cut are consistently too small - an 11 5/16 Circles comes out
10 7/8.  X,Y axes are calibrated and equal.  I am using a .25 end mill and I have it set to cut on the inside of the circle.  Where do I look to correct this problem?  Is is stepover?
Re: Inaccurate Dimensions
« Reply #1 on: October 10, 2010, 06:15:33 AM »
Is everything cut too small. or just circles?
Can you post the .dxf and g-code for a simple circle?
As a guess, since your off by about 2 times the bit diameter, I'd say you're doing something wrong in Cut2D. Sounds like your cutting a pocket? If so, do you have an allowance set?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: October 10, 2010, 08:42:56 AM »
If you cut a circle 5 21/32 dia what is the error?
Graham
