Hello Guest it is October 21, 2026, 11:47:16 AM
Author Topic: A axis setup  (Read 27367 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: A axis setup
« Reply #10 on: November 02, 2006, 11:20:34 AM »
The only other thing I can think of is,  are you running unshielded cables and running power and signal wires together, ty-wrapped or worse still wrapped together with wire Tye's.
Graham.
Re: A axis setup
« Reply #11 on: November 06, 2006, 09:46:43 AM »
Hey Guys and Gals,
Thanks for the helpful responses.  I e-mailed the person that sold me the milling machine.  He had some great suggestions that helped me isolate the problem.  First I switched the wires from the control box to the stepper.  Same problem.  Then I switched the stepper motor (no small feat because of the couplings).  Turns out I have a bad stepper motor.  I have tried to take it apart and work on the wiring... no such luck.  Look out eBay - here I come.
Steve
Re: A axis setup
« Reply #12 on: November 06, 2006, 10:13:09 AM »
I had no trouble with these guys.
http://www.homeshopcnc.com/index.html
