Hello Guest it is November 22, 2026, 01:40:07 PM
Author Topic: Z axis only moves in one direction when jogging?  (Read 13787 times)
« on: October 08, 2010, 08:19:26 AM »
I installed Mach 3 v2.63 on my machine after my PC crashed and wouldn't start.  I ran this machine successfully for almost two years.  In setting up my pinout in which Z pins out port 1 on pin 6 and 7 stp and dir respectively.  I only get clockwise rotation.
I swapped out the stepper (IMS Mdrive 23) and that had no result.  Swapped keyboard to rule that out. Pinned out onto the X axis and that didn't help.  Finally I decide to change the direction pin to 8 instead of 7 because I thought it might be something with the port.  That produced no result.
I figured before I went any further I would throw it out there.
Thanks.
Re: Z axis only moves in one direction when jogging?
« Reply #1 on: October 08, 2010, 09:46:58 AM »
check you haven't got a pin number duplicated
« Reply #2 on: October 08, 2010, 10:31:34 AM »
I'm all good in that respect. No dupe's.
« Reply #3 on: October 08, 2010, 12:53:11 PM »
Is it just when jogging or does it also happen if you MDI a move one way then the other?
Have you tested at the port with a voltmeter to see if the dir signal changes when you jog one way then the other?
« Reply #4 on: October 13, 2010, 11:20:35 AM »
Turned out to be a short in the wiring harness.  What a pain.
