Hello Guest it is November 20, 2026, 09:03:10 AM
Author Topic: Z direction problem  (Read 8968 times)
Z direction problem
« on: October 07, 2010, 05:17:10 PM »
Help!I have just purchased a Denford Orac lathe running mach3.My problem is when i set program coords on the end of a bar the x axis works fine but the z axis moves towards the tailstock when the program reads a z- value.My machine reference Z0 is by the chuck.I have tried reversing the z axis by unticking the z box in the config/motor home/soft limits box,however when i tried referencing the m/c it tried to go all the way to the tailstock and hit the z soft limit switch!!!Any help/suggestions
would be appreciated.
Rich.
Re: Z direction problem
« Reply #1 on: October 07, 2010, 06:23:24 PM »
Is it possible you hooked the motor wires up wrong?
« Reply #2 on: October 08, 2010, 03:43:29 PM »
I have managed to sort it temporarily by switching the z axis direction in the config/ homing/limits box.
