Hello
Guest
it is
November 08, 2026, 03:20:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
What Do You Think?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: What Do You Think? (Read 27115 times)
TramAlot
129
Re: What Do You Think?
Reply #10 on:
October 07, 2010, 10:54:25 AM »
sweet, I love the roooooooooom
Jim_V
11
Reply #11 on:
October 13, 2010, 01:04:27 AM »
Alright, now that I got the main computer figured out, I need a pci parallel port card that will work. A lot of the threads on here have dead links to what people use. I did find this one in a post however:
http://www.rogersmachine.net/PCIport.html
will this one work? If not, any links to ones that are proven to work would be appreciated, thanks.
JHChoppers
363
Reply #12 on:
October 13, 2010, 10:41:17 AM »
What PC did you choose ? The HP D530 has a parallel port in it.
Jim_V
11
Reply #13 on:
October 13, 2010, 10:58:58 AM »
I ended up getting a PC from my brother in law. 2.5 GHZ, 1 gig ram, 320 gig hard drive. It has an rs232 port which is what I thought I needed, but not a parallel port.
Jim_V
11
Reply #14 on:
October 13, 2010, 11:46:45 AM »
I'm also running windows 7 32 bit if that makes any difference.
TramAlot
129
Reply #15 on:
October 14, 2010, 09:22:54 AM »
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4959294&CatId=1422
serial
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4624354&CatId=512
both work well.
Jim_V
11
Reply #16 on:
October 14, 2010, 11:43:55 AM »
Will they work with windows 7?
Also, so you have to do anything special with settings or anything so the card works in EPP mode or whatever is needed, or just install it with the right drivers and call it good?
Last Edit: October 14, 2010, 11:56:37 AM by Jim_V
Print
Pages:
1
2
Go Up
« previous
next »
