Hello Guest it is November 19, 2026, 02:32:30 AM
Author Topic: Tool Path display  (Read 27028 times)
Re: Tool Path display
« Reply #10 on: September 30, 2010, 02:30:55 PM »
You also have a few outputs which share the same pins as the motors, so best sort that out as well.
« Reply #11 on: September 30, 2010, 04:25:11 PM »
Based on my interpretation of the configuration guide I believe it is configured correctly, I have attached the info for review.
The problem only seams to be when we change fixture offsets during any given program. If we just use G54 things run fine.
« Reply #12 on: September 30, 2010, 04:30:17 PM »
Please help me a little here, where about in the manual that you attached should I look?
« Reply #13 on: September 30, 2010, 04:40:10 PM »
The maping is on pages 32 thru 37 covers each section
« Reply #14 on: September 30, 2010, 04:44:51 PM »
Have you attached the correct manual? That is the standard Mach manual and I can assure you that when using the parallel port, or as far as I know, any other external device with Mach, you can not share ports and pins especially if you are specifying some of them as Inputs and some as outputs.
« Last Edit: September 30, 2010, 04:46:23 PM by Hood »
« Reply #15 on: September 30, 2010, 05:15:43 PM »
Yes I attached the wrong manual, I am currently geeting all the configuration info confired. I will send when I have all the data correct
Sorry for the confusion, FIY this is an either net connection
« Reply #16 on: September 30, 2010, 05:19:12 PM »
Ok I am at this time reading the DSPC manual that I have just downloaded and it seems that it indeed can be configured all as port 1 but the actual wires connect to different connectors on the DSPMC.
I am afraid I wont be able to test things here as I dont have the DSPMC :(
Have you talked to the DSPMC people about this as I suspect it may be a plugin issue.
« Reply #17 on: September 30, 2010, 05:38:51 PM »
OK I have attached a config pdf witch has the current I/O connections for the DSPMC controller showing the mapping. I have also attached the correct manual for the DSPMC,
Thank you again for your help
« Reply #18 on: September 30, 2010, 05:48:01 PM »
As said in my last post I am afraid I cant test due to me not having a DSPMC :(
Have you asked DSPMC people about this as it seems to me it may be a plugin issue.
Maybe a post on the DSPMC part of the forum will get answers if you have not already cdone so.
« Reply #19 on: October 01, 2010, 02:46:52 PM »
Just been looking at your xml again and see you have strange values for the SoftLimits. This may again be meant to be that way due to it being a DSPMC but normally with any other device I have seen you would have zero for X and Y min and Z Max and then X and Y Max would be the travel distance and Z Min would also be the travel but as a negative value.
Just wondering if that might be your problem?
