Hello Guest it is October 02, 2026, 08:59:52 AM
Author Topic: New Parallel Port not working  (Read 26706 times)
Re: New Parallel Port not working
« Reply #10 on: September 26, 2010, 03:16:14 PM »
Can you change it to EPP?
« Reply #11 on: September 26, 2010, 11:40:45 PM »
I can't find anywhere in the CMOS to change to EPP. This is getting to be a serious pain in the ass. I guess tomorrow I'll take it in and see if the experts can fix it. I'll also change out the RAM in my old PC and see if that makes a difference.
« Reply #12 on: September 27, 2010, 01:29:11 AM »
You wont find it in the BIOS if its a PCI card, Your only options may be in the device manager or possibly a jumper on the card itself.
« Reply #13 on: September 27, 2010, 08:40:11 AM »
did you install the driver?
also look in the device manager and see what info is there.
what make card?
« Reply #14 on: September 27, 2010, 01:37:29 PM »
Yes
Parallel Port addres is cc00
what make card?
Best Connectivity PCI Express
« Reply #15 on: September 27, 2010, 01:38:40 PM »
I wonder if it is that I am running a 64 bit version of Vista????
« Reply #16 on: September 27, 2010, 01:58:52 PM »
Thats it for sure, Mach will not run under 64bit versions unless you are using an external pulsing device such as SmoothStepper, DSPMC, Galil etc etc.
« Reply #17 on: September 27, 2010, 02:15:36 PM »
Wow, can't believe it took me this long to catch that. Hopefully I can get X loaded and see if we can make some progress today. I'll keep you posted.
« Reply #18 on: September 28, 2010, 12:05:18 AM »
Well I couldn't get my version of XP to load. I went out and got a used PC and I'm back at making chips. This PC is running XP, one thing I noticed and I also noticed this on my other PC with XP is that when you load a program into Mach the Reset button doesn't flash. It did when running under Vista. Is this normal?
