Hello
Guest
it is
November 22, 2026, 07:42:16 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Acu-rite Glass Scale Position-Trac Coding
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Acu-rite Glass Scale Position-Trac Coding (Read 30807 times)
BR549
6,965
Re: Acu-rite Glass Scale Position-Trac Coding
Reply #10 on:
September 23, 2010, 10:35:41 PM »
IF memeory serves me someone already did it. The system uses a speacially marked scale that has a positional pattern encoded into the scale ouput.
The system used a math calculation from the signal to decode its location. From a cold start all you had to do was start a slow move and as soon as it passed one of the signals you could determen where you were at then set that as current location and then you had to move to Machine zero and reset Machine coords.
OR something similar
I think is was on the yahoo forum years ago. I will try to find the info I have a copy of it somewhere here. SOMEWHERE
pofo
55
Reply #11 on:
September 24, 2010, 12:23:18 AM »
Yes! That is it. It would be great if you can locate it. I've been searching with no luck.
BR549
6,965
Reply #12 on:
September 24, 2010, 10:39:48 AM »
What model scales do you have? Have you tried acurite support to explain the sequencing???
Once you understand how the position sequenced itself the rest would be easy.
BR549
6,965
Reply #13 on:
September 24, 2010, 04:04:26 PM »
I found part of the discussion it was for a differrent manf
http://www.heidenhain.com/fileadmin/pdb/media/img/571_470-24.pdf
But the process in Mach should be the same. The trick is in how you reset Mach's machine zero value so it represents the calculated encoder position values.
Mach support discussion::
http://www.machsupport.com/forum/index.php/topic,9771.0.html
Still looking for the other discussion BUT i am afraid it went to an email discussion so it MAY be gone by now.
Last Edit: September 24, 2010, 04:15:14 PM by BR549
BR549
6,965
Reply #14 on:
September 24, 2010, 04:21:44 PM »
OOPS that was not a different MANF it was a different model.
pofo
55
Reply #15 on:
September 24, 2010, 04:38:59 PM »
Thanks. Those two links are big help. The Heidenhaim link is enough to get me going. Acurite was no help, which I don't understand. How can they sell a product but not have a tech sheet explaining one of the features.
Print
Pages:
1
2
Go Up
« previous
next »
