Hello Guest it is November 08, 2026, 03:10:11 AM
Author Topic: Acu-rite Glass Scale Position-Trac Coding  (Read 30541 times)
Re: Acu-rite Glass Scale Position-Trac Coding
« Reply #10 on: September 23, 2010, 10:35:41 PM »
IF memeory serves me someone already did it. The system uses a speacially marked scale that has a positional pattern encoded into  the scale ouput.
The system used a math calculation from the signal to decode its location. From a cold start all you had to do was start a slow move and as soon as it passed one of the signals you could determen where you were at then set that as current location and then you had to move to Machine zero and reset Machine coords.
OR something similar
I think is was on the yahoo forum years ago. I will try to find the info I have a copy of it somewhere here. SOMEWHERE
Offline pofo
  •  55 55
« Reply #11 on: September 24, 2010, 12:23:18 AM »
Yes! That is it. It would be great if you can locate it. I've been searching with no luck.
« Reply #12 on: September 24, 2010, 10:39:48 AM »
What model scales do you have?  Have you tried acurite support to explain the sequencing???
Once you understand how the position sequenced itself the rest would be easy.
« Reply #13 on: September 24, 2010, 04:04:26 PM »
I found part of the discussion it was for a differrent manf   http://www.heidenhain.com/fileadmin/pdb/media/img/571_470-24.pdf
But the process in Mach should be the same. The trick is in how you reset Mach's machine zero value so it represents the calculated encoder position values.
Mach support discussion:: http://www.machsupport.com/forum/index.php/topic,9771.0.html
Still looking for the other discussion BUT i am afraid it went to an email discussion so it MAY be gone by now.
« Last Edit: September 24, 2010, 04:15:14 PM by BR549 »
« Reply #14 on: September 24, 2010, 04:21:44 PM »
OOPS that was not a different MANF it was a different model.
Offline pofo
  •  55 55
« Reply #15 on: September 24, 2010, 04:38:59 PM »
Thanks. Those two links are  big help. The Heidenhaim link is enough to get me going. Acurite was no help, which I don't understand. How can they sell a product but not have a tech sheet explaining one of the features.
