Hello Guest it is November 18, 2026, 07:57:01 PM
Author Topic: Motor RPM  (Read 20902 times)
Motor RPM
« on: September 20, 2010, 01:15:14 PM »
Hi all
I am only asking, maybe it does exist somewhere, but I haven't found it yet??
A feature in the Motor tuning section that tells you the motor RPM, is it a simple count thing?? based on number of steps per revolution you set
can mach calculate and then display actual (calculated) RPM in a window on the Motor tuning page, might come in handy
Thank you
Re: Motor RPM
« Reply #1 on: September 21, 2010, 02:25:11 AM »
I assume you're wanting this for the axes motors. You could easily do this in a brain or a macropump if you found a way to extract the feedrate of each axis from the blended feed DRO ;) Not so easy I think.
