Hello Guest it is October 21, 2026, 08:02:28 AM
Author Topic: Motors are buzzing???Help  (Read 34952 times)
Re: Motors are buzzing???Help
« Reply #20 on: September 21, 2010, 10:59:22 AM »
Load the code then once open in Mach click the Edit button, it should open in notepad and yo can then type in G20 on the first line of the code. Close it and it will ask if you want t save, say OK and then thats it.
« Reply #21 on: September 21, 2010, 11:03:06 AM »
Hi Hood
Did try the edit button, the load screen (Please wait generating path)flashes and then nothing, no notepad, maybe its because i have the demo version?
Peter
« Reply #22 on: September 21, 2010, 11:32:19 AM »
Do you have the code opened in Mach first before pressing edit?
If so then go to Config menu then General Config and you will see at the top in the middle section the editor address, choose browse and go to  C:\Windows\ and choose notepad.exe
« Reply #23 on: September 21, 2010, 12:35:07 PM »
Your a star, thank you.
Worked a treat, just got to sort out with the supplier the motor speed limitations
and then buy the license for mach
Hopefully this is the start
I can then look at doing some drawings etc and converting to code to run through mach
Then start the table build (easy'ish bit)
Peter
« Reply #24 on: September 21, 2010, 12:55:23 PM »
Sorry
not yet the start, still have to work out the limits, homes, soft limits, Z axis (floating)THC, etc etc etc so will be a few more posts I think and a lot more questions for definite
thank you for everything so far
Peter
« Reply #25 on: September 21, 2010, 01:54:27 PM »
No probs :)
