Hello Guest it is October 20, 2026, 07:45:20 PM
Author Topic: G31 does nothing, in probing wizard and MDI...HELP  (Read 31651 times)
« on: September 18, 2010, 08:56:50 PM »
I have been trying to figure this out for hours.
I have been searching this forum, google and cnczone, and have found no answers.
I have a renshaw probe set up on my 3 axis bridgeport, i have it running through a SS breakout board, a Smooth stepper and in to mach 3. The probe is functional. I can get the diagnostics "digitize" led to light when  i manually touch the probe.
first I tried the wizzard for digitize and the Z never drops (with G31) to touch the item im digitizing. Then I tried the digitizing plugin, but I get a strange error. much searching has led me to believe that the plugin cannot be used with current version of mach 3.
So, I went back to the wizzard thinking it was the settings I was entering into it. no such luck. more googleing led me to test if G31 was working in MDI. I tried it a dozen times in MDI and the machine and mach DRO does not move with the G31 command. i tried it for x, y and z, G31 does nothing. no machine movement, no dro changes etc...
All this leads me to believe that for some reason G31 does not work. I have searched for hours, checked my settings over and over, and I cant figure out how to get G31 to work.
I hope someone here can help. I sure could use it.
Re: G31 does nothing, in probing wizard and MDI...HELP
« Reply #1 on: September 18, 2010, 10:21:17 PM »
Can you give me an example of the code you used in the MDI.
DId you set the feedrate??
« Reply #2 on: September 18, 2010, 10:33:50 PM »
I just used G31 X1 in did not set a feedrate.
Could you give me an example of code that you think would work in MDI?
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: September 19, 2010, 03:20:02 AM »
A straight G31 Z1 (or whatever) should give you DRO movement regardless of whether you even have a probe fitted so something is definitely not right. I just installed the latest lockdown and it works fine here. That said I'm using the PP driver and your using SS so hopefully someone who also uses the SS and latest lockdown will chime in. BUT I would have thought that you'd get DRO movement even if you didn't have ANY driver fitted so I'm a tad stumped on this one.
Ian
EDIT: Have you got your signal activation logic the right way round? If your probe is already active when you command a g31 then it will be ignored. If that is the case mind you should get a "Probe ignore, Activated at call for probe" message in the status line.
« Last Edit: September 19, 2010, 03:46:11 AM by stirling »
« Reply #4 on: September 19, 2010, 10:42:50 AM »
OK try it again from the MDI and IF you get no movement OR DRO changes , look at the bottom of the screen at the STATUS line. It gives you system messages that may give us a clue.
G31 with zero feedrate will give you the same as you see
AS WELL as what Stirling says will also give you the same.
The status message should help
Just a thought, (;-) TP
« Reply #5 on: September 19, 2010, 11:51:35 AM »
Well, I have tried it a bunch of times again, I believe that my probe is configured correctly as when I set it to the other setting, it gives me the error ""Probe ignore, Activated at call for probe"" I have it set so I DONT get that error.
I have tried the wizard again, and mach is running the wizzard, but the z never descends to probe. it only moves in y and x.
I went to MDI again, and I can imput G31 X2 F10 or G31 X22 or G31 Z-.1 and I get no movement at all. Its as if it just does not reckognize G31 command.
I can however enter G00 comands in MDI and they are executed.
I am not getting any errors while running the wizard or MDI imput. its just like Mach is just skipping over the G31 commands...
Stumped.
« Reply #6 on: September 19, 2010, 11:54:34 AM »
is their a cheat? is their a way to hand write the Z down probing code then I can just write a program with xy locations that incrementally change and insert the Z down probing code into it?
I am getting the strong feeling that G31 is not an option.
« Reply #7 on: September 19, 2010, 12:44:02 PM »
Is this a licensed version or the DEMO version???
DOES the dro show movement but the machine does not move?
SO there are NO messages at the status bar after you type in G31 X1 F10 ??
WHat version of mach3??
Are you using the standard screenset??
« Last Edit: September 19, 2010, 12:47:58 PM by BR549 »
« Reply #8 on: September 19, 2010, 01:17:57 PM »
Everything is fully lisenced in my name.
DRO shows no movement.
No messages when G31 X1 F10 is entered.
Mach Version R3.042.040
I believe that I am using the stock standard screenset.
« Reply #9 on: September 19, 2010, 01:20:30 PM »
Here is a word file that shows my settings. this was done last night.
