Hello Guest it is November 08, 2026, 12:06:46 AM
Author Topic: removing the print driver  (Read 10363 times)
« on: September 18, 2010, 02:42:56 PM »
While i have the galil plugin installed, should I remove the print driver.
If so how would I remove it?
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: removing the print driver
« Reply #1 on: September 20, 2010, 08:31:19 AM »
I have not had troubles leaving the driver on the machine. You select the driver for the Galil and I believe that Mach then ignores the PPort driver.
Kenny
Having way too much fun! Something must surely be wrong.
« Reply #2 on: September 20, 2010, 08:34:11 AM »
Ok. I've had no problems,  but wasn't sure.
Thanks steve
