Hello Guest it is November 22, 2026, 07:05:09 PM
Author Topic: incorrect dimensions when inverting x axis  (Read 36480 times)
Re: incorrect dimensions when inverting x axis
« Reply #20 on: September 17, 2010, 03:11:44 AM »
good day hood,
there is nothing wrong...nor the machine nor any program
the only change while milling circles after changing X axis is that they are made counterclockwise in stead of clockwise
so with a rather dull milling tool in wood we got incorrect dimensions
we will try to ask lazycam to program the circles counterclockwise to verify (you know is is possible?)
thanks again
a.willems
« Reply #21 on: September 17, 2010, 05:16:16 AM »
Sorry dont use LazyCAM but I am sure you will be able to specify climb or conventional milling.
Glad you found the problem :)
« Reply #22 on: September 21, 2010, 04:07:34 AM »
what is your best way to go from .DXF files to G code?
'specify climb or conventional milling' ?????
a.willems
« Reply #23 on: September 21, 2010, 06:29:39 AM »
Depends on your budget I suppose, a lot of people use LazyCAM and I believe Rich has written a manual which should be in the user docs part of the forum.
Climb milling is when the cutter is pulling itself in the feed direction, conventional is when the cutter is pushing against the feed direction.
« Reply #24 on: September 21, 2010, 06:30:29 AM »
Heres a link I got from a quick google search, it shows better than I have explained. http://www.quadrantepp.com/default.aspx?pageid=201
« Reply #25 on: September 23, 2010, 02:35:44 AM »
many thanks hood
yes the incorrect dimentions came from the same .dxf file but when changing X axis the milling changed from conventional to climb or vice versa
we got a difference of 2x 0.5mm = 1mm in multiplex (wood)
so we have to master the milling direction for critical figures. You know an easy way ????
a.willems
