Hello Guest it is November 01, 2026, 01:05:10 PM
Author Topic: LazyCam and Autocad 2011  (Read 9790 times)
« on: September 12, 2010, 07:51:24 PM »
Hi All.
I am just getting started using Lazycam. I am trying to use the MILL_LCR)_HCIR file that the manual refers to. Downloaded it from this site, and tried to save it as a DXF file without making any changes to the drawing. When I try to open it in lazy cam, it does not display anything. I have tried to save it in all the different DXF file that Autocad can save in, but non of them work.
If I try to open the original DXF, it works fine.
Is anyone else having any issues with Autocad 2011? What else can I try?
I have tried to uninstall and reinstall Lazycam.
I have attached the DXF file.
Mark
« Last Edit: September 12, 2010, 07:54:46 PM by markdem »
Re: LazyCam and Autocad 2011
« Reply #1 on: September 12, 2010, 08:41:10 PM »
Does 2011 save as v12 .dxf? That's the one you should use.
However, the file looked OK to me in 2009. I don't use LC, so can't help there.
« Reply #2 on: September 12, 2010, 08:47:58 PM »
Hi All.
I found the issue. I can get the file to open in Lazycam only if Autocad is closed.
Is this a known issue?
« Reply #3 on: September 13, 2010, 05:16:01 AM »
The dxf file is still in use by Autocad so you need to close the file Autocad. Two programs are accessing the same file.....
