Hello Guest it is October 20, 2026, 03:02:15 PM
Author Topic: feed rate  (Read 35788 times)
Re: feed rate
« Reply #10 on: September 15, 2010, 05:50:49 PM »
Is that all of it?
Try:
Code("G53G0Z-0.5")
While IsMoving()
sleep 100
Wend
Code("G53G0X24Y1")
While IsMoving()
Sleep 100
Wend
Re: feed rate
« Reply #11 on: September 16, 2010, 12:31:05 AM »
does not work, fedd rate still as per previous tool path
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
Re: feed rate
« Reply #12 on: September 16, 2010, 06:04:55 AM »
Is there more code?
Re: feed rate
« Reply #13 on: September 16, 2010, 11:20:35 AM »
Nope this is it.....
Thomas
http://big-tex.tk/
Re: feed rate
« Reply #14 on: September 18, 2010, 07:19:19 PM »
What is in the M6end macro??  A tool change is 2 parts M6start and M6end
Re: feed rate
« Reply #15 on: September 18, 2010, 08:04:26 PM »
what ever mach3 comes with i have not changed it at all
Thomas
http://big-tex.tk/
Re: feed rate
« Reply #16 on: September 18, 2010, 10:10:11 PM »
I think the answer is in the M6end macro. It deals with safez IF z >safez then it does a traverse move and that may be at Frate IF Z=< than safez then it moves at rapid rate.
Might want to check that. It may explain the different rates.
Re: feed rate
« Reply #17 on: September 19, 2010, 01:36:49 AM »
REM The default script here moves the tool back to m6start if any movement has occured during the tool change..
x = GetToolChangeStart( 0 )
y = GetToolChangeStart( 1 )
z = GetToolChangeStart( 2 )
a = GetToolChangeStart( 3 )
b = GetToolChangeStart( 4 )
c = GetToolChangeStart( 5 )
if(IsSafeZ() = 1) Then
   SafeZ = GetSafeZ()
   if  SafeZ  > z then StraightTraverse x, y,SafeZ, a, b, c
      StraightFeed  x, y,  z  , a, b, c
else
Code"G00 X" & x & "Y" & y
end if
That is how my unmodified m6end looks like
Thomas
http://big-tex.tk/
Re: feed rate
« Reply #18 on: September 19, 2010, 01:39:44 AM »
but it does not move at rapid rate that is whole point. it moves at previous feed rate to last location within last tool path.
I think I found bug in my script for probing, it sets feed rate to prior feed rate.
« Last Edit: September 19, 2010, 01:46:40 AM by big-tex »
Thomas
http://big-tex.tk/
Re: feed rate
« Reply #19 on: September 19, 2010, 02:03:10 AM »
Ok now that I found where it comes from and tested it.
I would like to add command to my script f=rapid feed rate
How would I do that?
Thomas
http://big-tex.tk/
