Hello Guest it is November 20, 2026, 06:27:17 AM
Author Topic: gcode from CAMBAM not running  (Read 10429 times)
« on: September 11, 2010, 11:11:59 AM »
I downloaded a trial STL file and loaded into CAMBAM.  Then I generated 3D machine pathways & gcode and save as .NC.  Then uploaded into Mach3.  Code shows up, but no project rendering in table display.  If I try to run code, it says "nested comment foundline 1" which refers to file name & date.  I even tried the older BAS Relief.   Projects I create myself in CAMBAM run just fine.  Any ideas?  Thanks  Marv
Re: gcode from CAMBAM not running
« Reply #1 on: September 11, 2010, 06:24:41 PM »
AND the file line in question reads???????
« Reply #2 on: September 11, 2010, 09:12:02 PM »
(BABY DOG-A (STL) 9/11/2010 8:47:11 AM)
« Reply #3 on: September 11, 2010, 09:19:36 PM »
I deleted the offending line of gcode & it appears to run normally.  My projects I have created all have the same info (except for the "-STL" part.  Maybe it doesn't like the "-" or the "STL" in the line?  Thanks
« Reply #4 on: September 11, 2010, 09:55:08 PM »
It does not like the double brackets  (  () ) It thinks the inside brackets are nested inside the outter ones.
