Hello Guest it is November 20, 2026, 02:16:13 AM
Author Topic: G Code Problem or Settings Problem??  (Read 8388 times)
« on: September 09, 2010, 10:37:05 PM »
Hello,
New to forum...I am trying to rout some v carved letters. Designed in V Carve...then converted to G-Code. Two other guys have used the same G Code, bit size, etc. with good results. (They do not use Mach) It seems like no matter what setting I try (in V Carve) the results are the same. The bottoms and tops of the letters are "bellied out".  The G Code is attached as well as a picture of the test.
My thought is...the G Code worked for two others...but not with my machine.  Is something setup incorrectly in Mach....I am lost on settings.. Any advise would be greatly appreciated.
Re: G Code Problem or Settings Problem??
« Reply #1 on: September 10, 2010, 05:17:34 AM »
TNROUTER,
Seems it's in the generated code from V Carve and I have no knowledge of V Carve. I would guess that if a straight line was in there like the pic it would clean up the bellies. Step through the code and note how the Z is changing along with the moves along the arc. It could also be a difference in your machine vrs theirs.
FWIW,
