Hello Guest it is November 13, 2026, 05:19:18 PM
Author Topic: Multiple information per line on LCD?  (Read 13180 times)
« on: September 08, 2010, 10:37:03 AM »
Hi all,
I would like to put 2 types of variables on each line of the LCD at a fixed starting position, is this possible.. If so..HOW? ???
ie.
Line 1: X-DRO and behind this (ofcourse at a fixed position) the feedrate
Line 2: Y-DRO and behind this (ofcourse at a fixed position) the spindlespeed
Line 3: Z-DRO and behind this (ofcourse at a fixed position) the jograte
Line 4: A-DRO and behind this (ofcourse at a fixed position) the toolnumber
I can get 2 variables on the LCD, however not at a fixed location..
Hope that someone can help me out (and probably others as well)
Cheers,
BriBis
Re: Multiple information per line on LCD?
« Reply #1 on: February 19, 2011, 12:36:01 PM »
Can you post how did you get 2 types of variables to one line of the LCD?
Maybe we can find a solution to your problem.
Milan
« Reply #2 on: July 06, 2011, 02:42:14 PM »
You are not the only person that sit whit this problem I havet he same problem I like to set also 2 variable on 1 line
is there something in documentation to find how I can solve this problem
« Reply #3 on: July 06, 2011, 06:10:45 PM »
guys, on your single line, insert spaces "    " between your "two" items, the first is the info on the left, then and in your space, then and in your secondary
display item.
scott
« Reply #4 on: July 07, 2011, 11:47:58 PM »
BriBis,
Here's a line from my macropump
setuserlabel(201,"X"& Format(getdro(0)," 0000.000;-0000.000")&" F"&Format(getoemdro(818)," ####00"))
The key is to make the first entry a fixed width. That's why I use the Format function. Hope it helps.
Zafar
« Last Edit: July 07, 2011, 11:50:22 PM by zafarsalam »
