Hello Guest it is November 13, 2026, 09:53:42 AM
Author Topic: Single line text in DXF format  (Read 17384 times)
« on: October 24, 2006, 02:43:50 PM »
I have been looking for a low cost (preferably free), single line, text generator that will support Ariel and other uniform thickness smooth fonts. It needs to be able to be ported into AutoCAD so I can size and position it with the cutout that it is to accompany. DeskEngraver seems to come close but it does not produce a DXF that AutoCAD 2005 can read (reports a file configuration error).
I want to be able to create custom shaped engraved faceplates/info-plates using a ball-nosed or V-nosed bit for the text. This is effectively 2D work with the text and pattern each on a different layer.
What would be really nice is if LazyCam would allow translating text direct from the DXF drawing file, However, I think that may be a bit much to ask.
Are there any good ideas out there for solving this problem?
Thanks.
Bill
Pixel Tamer
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Single line text in DXF format
« Reply #1 on: October 24, 2006, 03:42:10 PM »
Have a look at this software, free demo fully working.
Millwrite is the program, it is very good at text
Graham
« Reply #2 on: October 24, 2006, 06:41:27 PM »
You could try converting the .dxf with the free converter from www.a9tech.com
metal_twister
« Reply #3 on: October 25, 2006, 09:16:51 AM »
Google ttftodxf
That's True Type Font to DXF.
Free all over the place and works pretty well
« Reply #4 on: December 11, 2006, 11:03:04 AM »
Here is a free converter that allows curved text called deskengrave:
http://www.ezart.com/jump/jump-dk.htm
« Last Edit: December 11, 2006, 02:33:15 PM by dfurlano »
