Hello Guest it is November 07, 2026, 11:50:55 PM
Author Topic: mpg rate selection  (Read 10243 times)
mpg rate selection
« on: September 07, 2010, 08:43:21 PM »
has anyone ran across the situation where the mpg works well, but no change is noticed when selecting the different rates. with exception to the .0001 when the steps actually
become almost right on.. but no difference between .1 and .001........
steve
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: mpg rate selection
« Reply #1 on: September 07, 2010, 08:57:52 PM »
The rate is set in config>general config and can be changed at your whim. I have found that jog rate of .025" is about the maximum needed and .001" is good for general use. The rates are selected from the tabout screen when in MPG mode and jog is enables. A brain file can also be written to select both the axis and also the rate.
When properly set up the rate is exactly the setup rate.
Cheers,
Kenny
Having way too much fun! Something must surely be wrong.
