Hello Guest it is October 25, 2026, 10:56:32 PM
Author Topic: Toggling Outputs  (Read 9210 times)
Toggling Outputs
« on: September 07, 2010, 12:06:56 PM »
How do you toggle an output?
as it is right now the wiki shows output on/off 4-6 but no ability to toggle them
thank you
~Joe
  •  9,374 9,374
Re: Toggling Outputs
« Reply #1 on: September 11, 2010, 02:57:43 AM »
Joe,
One way is to create a VB screen button and paste in the following code ;
If IsOutputActive(OUTPUT5) Then ‘Check to see if its on
DeActivateSignal(OUTPUT5) ‘Its on so turn it off
Else
ActivateSignal(OUTPUT5) ‘Its off so turn it on
End If
Obviously this is for Output #5 change for whichever output you wish to toggle.
« Reply #2 on: September 28, 2010, 05:01:01 PM »
I am trying to make this script:
‘ Show the user the state of the Y HOME input
If IsActive(YHOME) Then
MsgBox “Y HOME is active”
Else
MsgBox “Y HOME  is inactive”
End If
But when I debugg it and I put the mouse over YHOME to see its value shows YHOME = "5" no matter if is active or inactive always the same then acts as always false the statement.
what wolbe happening here? ???
« Reply #3 on: September 28, 2010, 05:03:26 PM »
Else
End If
