Hello Guest it is November 13, 2026, 09:46:40 AM
Author Topic: need help z axis how will engraving down  (Read 12072 times)
« on: September 06, 2010, 01:47:31 PM »
 hi iam newbie please i have funny problem after load gcode i press start my z axis should engraving into wood i gose oppisiet it go up ? how it will engraiving down not up  can anyone explain please?  :-[
Re: need help z axis how will engraving down
« Reply #1 on: September 06, 2010, 03:21:14 PM »
If you press the PgUp button does the axis go up and does the Z DRO go in a positive direction?
« Reply #2 on: September 07, 2010, 05:46:50 AM »
sorry for delay, when i press pageup and page down nothing happening , idid set up my key board direction of axiss for z axis  is A for  UP and  D for DOWN  its working axis go up and  down by A AND d my gcode is GO Z1.0000  and on mach3 page XYZ4 ALL +0.00000 WEN I PUT gcode  the z go down , and when it start engraving it slowly engraving up that all thanks fro you help,
« Reply #3 on: September 07, 2010, 06:02:59 AM »
Ok so if you are at Zero in the Z and you command a move to Z1 it goes down? If that is correct then you need to reverse your axis as Z1 should be up and Z-1 would be down. To change the direction go to Config menu then Homing and Limits page and then reverse for the Z axis.
« Reply #4 on: September 07, 2010, 06:14:36 AM »
thank you very much its done now thanks for  your help
« Reply #5 on: September 07, 2010, 06:22:22 AM »
