Hello Guest it is November 13, 2026, 02:02:29 PM
Author Topic: Galil to Mach  (Read 9484 times)
Galil to Mach
« on: September 06, 2010, 01:34:17 AM »
Hallo,
I'am new with Galil and Mach. I would like to implement a hendheld with MPG. I had seen the videos about Brains und had reading about it.. but can't use it without more informations...
Can somebody help me please with four brains. Thirst from Galils analog input3 to Machs feed override, second from Galils analog input4 to Machs speed override, third Galils digital input IN1+IN2(logical 1,1/0,1/1,0/0,0) to Machs Axis selection (X,Y,Z,A)  and Galilis digital input IN3+IN4(logical.....) to machs handwheel resolution (config/geneal config 0.1/0.01/0.001/0.0001/)
Cooling will be activated by IN5+IN6+IN7+IN8 logical (1/1/0/1)
Ref by logical (0/1/0/1)
I hope some can help me with the implementation.
In advance, thanks for your efforts
Regards
Claus
Re: Galil to Mach
« Reply #1 on: September 06, 2010, 02:06:09 AM »
Doing the Brain, at least for FRO and SRO would be easy enough but afraid I know nothing about how the Galil inputs are named in Mach so cant really advise. You would be best to post this in the Galil section of the forum as they will likely know.
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: Galil to Mach
« Reply #2 on: September 06, 2010, 10:40:56 AM »
Claus,
Please refer to the PDF for the Galil plugin that is available on the plugin downloads page. We use a special method of implementing MPG for Galil and it is described in that document.
Cheers,
Kenny
Having way too much fun! Something must surely be wrong.
