Hello Guest it is October 24, 2026, 07:01:15 AM
Author Topic: N00b 2.5D Question  (Read 10613 times)
N00b 2.5D Question
« on: September 05, 2010, 07:53:24 PM »
Hi All -
I'm setting up a 2.5D system (manual Z-axis) and was trying to find a way to get Mach3 to pause and wait for input when it gets a command to
move in Z.  I'm sure there's got to be a configuration button somewhere obvious, but I'm totally missing it.  Can y'all give me a shove in the
right direction?
Jamie
Re: N00b 2.5D Question
« Reply #1 on: September 06, 2010, 01:13:02 AM »
This has been asked quite a few times from memory and I dont think I recall seeing a way to do it in Mach. Easiest way would be to use a text editor and do a search and replace in you code, seqarch for the Z moves and replace with a M1
« Reply #2 on: September 11, 2010, 07:41:46 PM »
can you do this with a tool change instead?
