Hello Guest it is November 13, 2026, 05:20:20 PM
Author Topic: Is PoKeys fast enough?  (Read 11141 times)
« on: September 04, 2010, 12:47:32 PM »
Hi all,
I was wondering if Pokeys is fast enough to connect a toolheight-sensor to one of it's ports (without crashing into the base of a mill ofcourse)?
Is there any difference between the parallelport and Pokeys with reference to communication-speed?
BriBis
Offline borisz
  •  220 220
    • www.poscope.com
Re: Is PoKeys fast enough?
« Reply #1 on: September 05, 2010, 11:15:50 AM »
Hi!
The main and most important difference is that PoKeys is USB HID device.
USB does not guarantee data delivery in a time. You can avoid that if you secure that PoKeys is only device on USB controller and if you do not use any mass storrage (USB disk or key), USB printer and other USB devices which needs high data transfer at the same time.
regards
Boris
