Hello Guest it is November 07, 2026, 11:56:48 PM
Author Topic: Physical override pots with Galil  (Read 10616 times)
« on: September 01, 2010, 10:32:57 PM »
I would like to keep most of the physical controls from my Dynapath control (cycle start, feed hold, E-stop, feed rate override, spindle speed override).  I think I can handle the first three, but I'm not sure about the override pots.  Would I wire the wiper to an analog in on the Galil and write a brain for Mach, or is there a better way?  I though about just doing the spindle speed override with a Galil program, but I don't think this would work for feed rate.
Mike
Offline smurph
  •  1,575 1,575
Re: Physical override pots with Galil
« Reply #1 on: September 02, 2010, 12:23:40 AM »
Yes, analog to the Galil, value to the user DRO range specified in the config dialog general tab, and then do a brain to move that user DRO value to the appropriate Mach DRO.
That way, when you turn the knob, the Mach screen also updates.
Steve
« Reply #2 on: September 10, 2010, 08:55:32 AM »
Thanks for the help, that was easy enough.  Just one detail for the record, with the 5-8 axis 2000 series boards the analog ins are only available on the A-D cable.  I had been using the E-H axes because of some earlier troubleshooting.
Mike
