Hello Guest it is October 21, 2026, 01:03:40 PM
Author Topic: Write Wizard  (Read 29173 times)
Write Wizard
« on: August 30, 2010, 09:13:58 AM »
I have tried to to get "Write" in the wizards to load a G code for simple engraving, but it will not post. Last week while working with the wizards and Lazy Cam I received a message that an axis was disabled, but that hasn't repeated. The Lazy Cam G code loads, but all fonts cut double line.
If you think you can't do it, you're right.
Re: Write Wizard
« Reply #1 on: August 30, 2010, 04:44:06 PM »
Did you fill in all the inputs, select a single line type of font, but........when all done you need to click the "WRITE" key on the wizard keyboard.
Otherwise it's won't post the gcode.  ;)
Re: Write Wizard
« Reply #2 on: August 30, 2010, 08:18:50 PM »
That did it Rich, Thanks. I'm not sure if I changed any inputs that mattered, but when I touched the write key, it stayed depressed until the G code had loaded and then reverted to the Mach3 screen and cut single line.
