Hello Guest it is October 25, 2026, 01:17:47 AM
Author Topic: no motor tuning under config  (Read 9503 times)
« on: August 22, 2010, 04:51:22 PM »
Hi, complete newbie so hope someone can help. Under config I have set all the ports and pins, but not output to my motors although the screen displays says they are turning. When I go to motor tuning under config nothing happens, no screen appears. What am I doing wrong? Thanks in anticipation.
Re: no motor tuning under config
« Reply #1 on: August 22, 2010, 04:55:58 PM »
Reinstall Mach over the top of itself making sure you choose the parallel port driver option and see if that helps.
« Reply #2 on: August 22, 2010, 09:04:21 PM »
I've also heard of this happening on PC's that are to slow for MAch3
