Hello Guest it is November 20, 2026, 01:52:34 AM
Author Topic: Repeat program and step down question  (Read 9096 times)
« on: August 22, 2010, 03:37:09 PM »
Hello, I am using 2Linc's engraving software to generate Gcode for engraving text. It appears to be standard Gcode that I can import directly into Mach3 as an nc file. It works well.  How do I repeat the program and step down .001 on the Z axis per program repeat? Thanks, Mike
Re: Repeat program and step down question
« Reply #1 on: August 22, 2010, 04:06:45 PM »
Try using the multipass wizard to create multiple passes.
« Reply #2 on: August 22, 2010, 04:30:16 PM »
Is that one of the  Mach wizards? I'm away from the machine and program right now.
« Reply #3 on: August 22, 2010, 05:04:22 PM »
Yes
