Hello Guest it is October 24, 2026, 12:00:44 PM
Author Topic: How do you manage the display window?  (Read 8572 times)
« on: August 17, 2010, 01:58:16 PM »
Can I zoom in on the disp[lay window? Change the jog follow back and forth? I thought I saw a video on it. Thanks, Mike
Re: How do you manage the display window?
« Reply #1 on: August 17, 2010, 04:12:34 PM »
To zoom in you can either click in the toolpath window and use the scroll wheel if using a mouse with a wheel or Press and hold shift key then click and hold left mouse and move mouse.
Jog follow should just require pressing the button to either switch on or off.
Warning here though, if using the parallel port you may get problems by doing anything to the graphics whilst running code as it may upset the pulse stream, will depend on your computer.
