Hello Guest it is October 23, 2026, 02:03:58 AM
Author Topic: Mach3 with minipc?  (Read 12008 times)
Offline koep
  •  23 23
Mach3 with minipc?
« on: August 11, 2010, 02:36:43 PM »
Hello Everyone!
Has anyone tried Mach with a Fit-pc or eBox ar any similar fanless minipc?
I'd be interested in hearing the results
Rgds,
Tapio
Re: Mach3 with minipc?
« Reply #1 on: August 11, 2010, 04:07:31 PM »
I use the Via Pico mobos in my machines, no parallel ports so I use the SmoothStepper as well. The Pico has a fan on it but I have seen them without.
The pico measures 100mm x 72mm for the motherboard and I also have a pico in an Artigo case that I have in the house for connecting to the TV.
Pics below, Pico for the mill and the Artigo with a CD on top showing the size.
Offline koep
  •  23 23
« Reply #2 on: August 11, 2010, 04:34:39 PM »
Hi Hood!
Thanks for the quick reply!
I take it from your answer that you get full performance out of this combo,
or atleast enough to be happy w/ it?
No problems due to the integrated video?
Does the pico have a hard disk or is it with CF/SSD?
Rgds
Tapio
« Reply #3 on: August 11, 2010, 04:41:28 PM »
No problems at all with the pico, the SS does the pulsing externally so a lot of the work is taken away from the PC itself. Integrated graphics are not a problem due to the fact that the software pulsing engine is not used.
The most I have seen on CPU was 30% and that was with a test of Rev4 of Mach, normally sits at 10% or less CPU.
The Pico has SATA and IDE for fitting hard drives, I use  2.5inch SATA drives.
Offline koep
  •  23 23
« Reply #4 on: August 11, 2010, 04:58:48 PM »
I think I have to start looking for a similar approach. I need to free floor space so I have to remod the whole electric enclosure so the
tower pc made for office floor has to go.....
thx again
tapio
