Hello Guest it is October 23, 2026, 02:58:51 AM
Author Topic: program causing pokeys to quit  (Read 13352 times)
Offline Bill_O
  •  615 615
« on: August 10, 2010, 06:45:41 PM »
I have a small program that runs when a button is pushed. Every time I run this program the pokeys is no longer seen. Here is the program. Any ideas?
SetUserLED (1220, 1)
ActivateSignal(Output3) 'turn on chiller
Sleep (2000)
ActivateSignal(Output2) 'turn on spindle
Code "S18000"
Sleep (120000)
Code "S27000"
Sleep (120000)
Code "S36000"
Sleep (120000)
DeActivateSignal(Output2) 'turn off spindle
Sleep (10000)
DeActivateSignal(Output3) 'turn off chiller
SetUserLED (1220, 0)
Bill
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: program causing pokeys to quit
« Reply #1 on: August 11, 2010, 02:54:38 AM »
Try this code, not sure it will be better but worth a try
Sleep (2000)
Code "S18000"
while ismoving()
  Code "G4 P1200"
wend
Sleep (1000)
Code "S27000"
while ismoving()
  Code "G4 P1200"
wend
Sleep (1000)
Code "S36000"
while ismoving()
  Code "G4 P1200"
wend
Sleep (1000)
Sleep (1000)
Graham
Offline Bill_O
  •  615 615
« Reply #2 on: August 11, 2010, 05:24:00 PM »
Graham,
It just ignores the g4 pauses. That is why I started using sleep commands. I tried it anyway and it did not pause at the g4 commands.
Thanks for the suggestion and I will gladly try anything. I have 2 machines to get out at the end of next week and both have a pokeys on them.
Bill
  •  2,785 2,785
« Reply #3 on: August 12, 2010, 02:31:57 AM »
OK, so lets try it a different way.
Put this code into the M3.m1s macro in the profile you are using, remove the current dospin() code :-
You can also put this in the M4.m1s too
Then put this into the M5.m1s macro as above :-
Then put this into a sub program in the subs folder of your profile, call it "warmup.tap" :-
(warmup.tap)
S18000
G4 P1200
S27000
G4 P1200
S36000
G4 P1200
M99
Your calling code would look like this :-
M3                         (turn on chiller and spindle)
M98 (warmup.tap)   (call spindle warm up sub)
M4                        (turn off chiller and spindle)
M30
Graham
Offline Bill_O
  •  615 615
« Reply #4 on: August 12, 2010, 09:44:27 AM »
Graham,
It tells me " Cannot load first file "
Exactly how do you put the m98 and file to call
Offline Bill_O
  •  615 615
« Reply #5 on: August 12, 2010, 09:45:21 AM »
also, it does go in the Mach3/Subroutines folder doesn't it?
« Reply #6 on: August 12, 2010, 11:22:36 AM »
Give it a try this way and see what happens
Sleep(100)
Sleep (1000)
Sleep(1000)
Code "S18000"
sleep(10)
Code"G4 P1200"
While Ismoving()
Sleep(1000)
wend
Code "S27000"
Sleep(10)
Code"G4 P1200"
While Ismoving()
sleep(1000)
Wend
Code "S36000"
sleep(10)
Code"G4 P1200"
While Ismoving()
Sleep(1000)
Wend
Sleep (1000)
Sleep(1000)
Sleep(100)
end
« Last Edit: August 12, 2010, 11:27:08 AM by BR549 »
