Hello Guest it is November 13, 2026, 09:24:35 PM
Author Topic: dual Z swap button help please  (Read 6391 times)
« on: August 09, 2010, 09:35:18 AM »
Hi all, i have read and learned a lot but not much of a poster.
Well now is my time to come to the well of knowledge.
What i have is dual z set up ( 2 z's, two routers and two motors everything) on the current screen set i have a swap z button which then uses the offsets to be able to use the A axis.
Depending on which "Z" is active the touch off button will zero that axis. the other thing is i didn't need a different PP.
All worked great, well till now. Before the motors and setup was exactly the same.
Now i have changed one of the setups so the motor setups are different.
When i swap to use "z2" which is my "A" axis it uses the "Z" motor tuning setups.
Here is my question; how do i change the set up to use the "A" axis motor tuning setup?  My experience with VB is that i have looked at it and sort of get what is going on, sort of.ng
I have attached my set files.
Thanks for taking the time to help.
Sean
