Hello Guest it is November 10, 2026, 01:54:55 AM
Author Topic: How to get from visualbasic value register in modbus?  (Read 7167 times)
Offline fbd
  •  1 1
« on: August 09, 2010, 06:14:12 AM »
subj
Re: How to get from visualbasic value register in modbus?
« Reply #1 on: August 11, 2010, 10:59:27 AM »
you can get to the OLD serial Modbus via VB but you cant get to the new Serial Plugin or TCP modbus by VB.
But, you CAN do it in a two step process........
I.e. I highly recommend you use the Serial plugin Modbus
pull in the info to a brain, shuttle it to a DRO then pull the dro with your VB.
scott
