Hello Guest it is November 02, 2026, 10:30:09 AM
Author Topic: Laser Modulation Output  (Read 7625 times)
« on: August 03, 2010, 02:49:11 AM »
Hello,
We're Converting an old Bystronic Lasermachine ( Co2 laser 1500 W ) To Mach 3,
Using the DSPMC To run the Old analog servodrives.
I've programmed a script in Bains that will modulate the laserbeam when the machine stops working.
When the actual speed < the requested speed.
I need id otherwise the machine cannot cut fine RVS or steel.
Is it possible to make some G or M codes to modulate an output ?
I've Also cutting gas control via an proportional valve.
The dspmc have 8 analog outputs,  Just 2 using for the axes.
Can i make an M code  and write a variable to an analog port ?
Thanks  Ronald.
I'll make some movies when everything starts to work.
