Hello Guest it is October 23, 2026, 06:17:16 PM
Author Topic: Z axis looses SPI setting?!?!?  (Read 22479 times)
Re: Z axis looses SPI setting?!?!?
« Reply #10 on: August 03, 2010, 05:16:44 PM »
The only thing I can think of is that your xml is set as read only, either that or Mach is not being shut down correctly as settings are only saved when you close Mach.
« Reply #11 on: August 03, 2010, 07:03:10 PM »
Is there a way I could edit it directly in the XML with the machXML reader???  And what line would I be looking for to change?
« Reply #12 on: August 04, 2010, 02:19:29 AM »
step0 is X step1 is Y etc etc.
