Hello
Guest
it is
November 22, 2026, 10:33:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach 3 and the use of a CMM as an engraver
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 and the use of a CMM as an engraver (Read 11709 times)
glengeniii
26
on:
August 02, 2010, 02:42:57 AM »
Does anyone know is CMM's us ball screws. I would like to scrap the controls on an old CMM, and retrofit it with Mach3 for use as a cnc engraver/router. Is this plausible?
Tweakie.CNC
9,378
Super Kitty
Re: Mach 3 and the use of a CMM as an engraver
Reply #1 on:
August 02, 2010, 07:59:18 AM »
I have never seen inside the bellows covers on one of these but due to high accuracy they operate at I would suspect micrometer type screw threads with anti-backlash nuts.
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #2 on:
August 03, 2010, 06:28:14 AM »
Most have ballscrews and linear scales for feedback and accuracy, your problem will be reading the scales for the measurements.
Most of the later ones also have a 3d model of the movement to compensate for position errors, twist and yaw.
Graham
pplug
15
Reply #3 on:
June 22, 2011, 05:58:36 PM »
I converted an omis III CMM I bought for $500 a few years ago. It was built in 1996 and looked like a standard moving table mill. I believe it was used for video inspection of auto parts. The base is made from 5" of cast granite and the incredibly sturdy gantry is made from cast aluminum legs and a ceramic crossbeam. The granite base rests on vibration dampeners fixed to it's own steel cabinet base. This thing was made sparring no expense! The linear motion components were comprised of thk linear bearings and old fashioned leadscrews.
The fist thing I had to do after I brough the beast Home was to fix an appropriate linear slide for the z axis and mount the router. I then used some used steppers and a xylotex motor controller to power it all up. The first year I used that machine to make a few thousand dollars! Many years later I replaced the xylotex with a g540 and the leadscrews with ballscrews. The machine is absolutely incredible and is faster and more precise than my Techno lc4896 retailing at $35K!
Print
Pages:
1
Go Up
« previous
next »
