Hello Guest it is November 17, 2026, 01:58:38 PM
Author Topic: PWM Spindle Control using Mach3 - How I did it  (Read 149777 times)
Re: PWM Spindle Control using Mach3 - How I did it
« Reply #50 on: November 08, 2015, 07:03:49 PM »
Got it.... Thanks
« Reply #51 on: October 25, 2016, 07:55:03 PM »
Am I correct in saying since this thread mentions VFD's it is for controlling an AC spindle motor?  I'm looking for direction on controlling a  DC spindle motor with Mach3.
« Reply #52 on: October 26, 2016, 12:03:23 AM »
Your assumption is correct.  Ac Motors only.
Chrisjh
« Reply #53 on: October 26, 2016, 03:41:19 PM »
Chrisjh
I have searched high and low trying to find out the basics needed to run a DC spindle motor from Mach3.  I am using a C10 breakout board - which I know will not support PWM.  If someone would give me a basic overview of what I need from a hardware standpoint I'd appreciate it.  Since Im already using up my parallel port, for the C10 board, Im thinking of using a RJ-45 breakout board.  Then, I'd go from the RJ-45 board to a DC motor controller to the DC motor.....would that work?
« Reply #54 on: October 26, 2016, 04:21:19 PM »
Controlling the spindle speed has little to do with the motor type, ac,dc,brushless, etc, and everything to to with the motor controller driving spindle motor.
It is the motor controller that  determines how you will drive your spindle motor.
What motor controller do you have? If all you have is a DC motor, what are the motors specifications, that is what is the rated voltage and current for the motor?
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
« Reply #55 on: October 27, 2016, 09:51:17 PM »
Using a treadmill motor PM-DC, Model C3354B3008, 21.4 Amps, 2.6 HP max, 1.5 HP @ 95 volts DC continuous.  As far as controllers, I hope to use the MC-60 controller that came off the treadmill.  I am open to suggestions if you think I should us another controller.
« Reply #56 on: October 29, 2016, 06:42:59 PM »
I don't have experience with this particular controller, but you may be able to get it to work.
I mainly use KB electronic controllers. The KBIC-125 below or similar should be suitable for your motor.
http://www.ebay.com/itm/KB-Electronics-KBIC-125-1-5-HP-90-VDC-OUT-115-AC-IN-MOTOR-SPEED-CONTROL/231944525239
You could then use a DC-03 Digispeed to then control it from Mach3.
http://www.homanndesigns.com/index.php?main_page=product_info&cPath=54_1&products_id=21
Cheers,
Peter
Homann Designs
