Hello Guest it is November 13, 2026, 06:25:56 PM
Author Topic: Z works fine but problem with X Y A 4Axis controler  (Read 10479 times)
« on: July 24, 2010, 05:14:57 PM »
Hey,
 I hope there is someone here who can help me solve a problem with my Mach3. I bought initially one controler and it all went right after the book, I was so unlucky that a wire to one of steppermotor hung in a screw, thereby causing a short circuit.
I have now bought a new 4 axis Controler: TA8435H and it looks good, I got the Z axis to be working fine, but XYA does not work, they only get power when I press estop, ( the flashes of Mach3 ). I've messed around with port and pins but could´n see what I have done wrong, hope you can give me a hint.
Thanks.
Regards
Jens Jorgen Hansen ::)
Denmark.
J J Hansen
Re: Z works fine but problem with X Y A 4Axis controler
« Reply #1 on: July 24, 2010, 05:27:33 PM »
Can you post a link to any info you have on the 4 axis driver, also attach your xml please.
« Reply #2 on: July 25, 2010, 06:43:29 PM »
 ;D
Hello, I am sorry to have disturbed you, I've got it to work, it was my stupidity that I had not removed "active low" as the old controler drove by (old one).
but a thousand thanks for your willingness to help so quickly.
I´m so happy, it works fine now
The happy dummi ;)
Regards JJ Denmark
J J Hansen
« Reply #3 on: July 26, 2010, 12:59:19 AM »
Thats great news and dont worry about it, everyone makes these kinds of mistakes :)
