Hello Guest it is October 23, 2026, 03:12:47 PM
Author Topic: DXF opening error: 0  (Read 73474 times)
Offline RossF
  •  31 31
« on: July 24, 2010, 05:05:53 PM »
I don't want anyone to get me wrong here. I am an absolute fan of this software and it's concept but there are a few frustrations on the part to Nirvana.
I have finally got LazyTurn working on my desktop 'puter but I just cannot get a dxf file to open.
I am presented with Error Found, LazyTurn Art Code: O, Attempt Recovery.
And clicking yes has no effect, while clicking no asks me to send a message to MS and then shuts down LazyTurn.
I cannot find any reference to Art Code: 0 anywhere.
Some help please.
Is there going to be a standalone install for LazyTurn sometime?
Re: DXF opening error: 0
« Reply #1 on: July 24, 2010, 07:56:53 PM »
Can you post the dxf file so i can have a look at it?
Eventualy LazyTrun will be standalone but until then follow the installation info given in the manual.
« Last Edit: July 24, 2010, 08:05:01 PM by RICH »
Offline RossF
  •  31 31
« Reply #2 on: July 24, 2010, 08:31:09 PM »
Hi Rich,
I think I've followed everything in the manual but it's difficult breaking old habits :)
Here is the dxf that I have tried most recently. I have also tried a few others but always end up with the same error.
Ross
« Reply #3 on: July 25, 2010, 08:04:46 AM »
Ross,
See appendix "B" in the manual, 3.6 Do not draw more than the top part / upper half of the profile....
See attached modified dxf.
Offline RossF
  •  31 31
« Reply #4 on: July 25, 2010, 02:07:22 PM »
Same result Rich. I had also tried your test file SECT_5_HCIR.dxf and still get the error message.
LazyTurn Art Code: 0
I should have pointed out, in my earlier post, that clicking Yes, for the Attempt Recovery option, just recycles the error message.
« Reply #5 on: July 25, 2010, 03:34:35 PM »
Those files should work...
May be an installation problem, so let me check something out and i will get back
Offline RossF
  •  31 31
« Reply #6 on: July 26, 2010, 01:59:02 PM »
Hi Rich,
I've included the error text file that is generated when LazyTurn is terminated.
Ross
« Reply #7 on: July 26, 2010, 02:16:57 PM »
Offline RossF
  •  31 31
« Reply #8 on: July 26, 2010, 04:06:27 PM »
Thanks for all your efforts Rich.
Ross
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #9 on: July 26, 2010, 05:46:46 PM »
Hi Ross:
 In general an "ArtCode" is simply an indication to me where in the porogram an error occured. A 0 doesnt mean much. Its a divide by zero, question is where..
  Did you delete your lazyturn.xml as a test? If it still occurs after that Id recommend updating your video drivers as its usually an OpenGL error in a video driver that can cause that, ( or at least thats when Ive seen it occur..).
Art
