Hello
Guest
it is
November 19, 2026, 09:03:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Creating GCode to cut a solar dish mold.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Creating GCode to cut a solar dish mold. (Read 10068 times)
Pythagoras
93
a² + b² = c²
on:
July 22, 2010, 08:29:28 PM »
If I wanted to make a mold for a 1 x 1 metre square reflective solar dish, and the focalpoint was to be 3metres away, how would I go about it?
How would I then ceate code to then cut this mold via 3 axis CNC.
Regards Benny
Logged
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c). a² + b² = c².
Pythagoras
93
a² + b² = c²
Re: Creating GCode to cut a solar dish mold.
Reply #1 on:
July 22, 2010, 09:37:11 PM »
Solution found
http://www.cerebralmeltdown.com/cncstuff/parabola/index.htm
Logged
kf2qd
157
Reply #2 on:
July 23, 2010, 03:17:52 PM »
Actually it isn't that hard - you would basically cut a bumch of circles with the z calculated off the radius to give you the right focal length. Don't have to be too picky witht he roughing cuts, but you would need to keep the radius changed small for th finish cuts. A ball nosed endmill (the larger the better for finishing)
Logged
Print
Pages:
1
Go Up
« previous
next »
