Hello Guest it is November 13, 2026, 01:23:31 PM
Author Topic: Rapid OverRide  (Read 9165 times)
Offline SScnc
  •  77 77
Rapid OverRide
« on: July 22, 2010, 08:48:10 AM »
Why do none of the lathe screen sets available have the ability to change the rapid speed. Only Feed Rate and Jog%, am I missing something here? I'd like to have what the Mill screen has with the slider. I don't really like going at full speed when running a part for the first time. Help?
~Scott
Re: Rapid OverRide
« Reply #1 on: July 22, 2010, 09:25:09 AM »
Two things you can do, first is make sure on General Config page that rapid is locked to FRO, that way when you reduce the FRO by 50%, or whatever, the rapid will also be reduced by that amount.
If you prefer total control then you can use one of the screen designer programmes and add a slider for Rapid  to your screen.
