Hello Guest it is November 13, 2026, 09:59:27 AM
Author Topic: Did I fry my Z axis?  (Read 10244 times)
« on: July 20, 2010, 02:36:41 PM »
So I am doing one of my typical production runs, cutting .080 sheet aluminum.  All is going well.  About 2hrs in, the machine runs the Z axis deep into the work, and I think tried to run it through the table before it physically stopped and Mach said an E stop was pressed.  I was in the next room do other work.  Nothing sounded bad, so it must have been a quiet death.
I tried to jog the Z axis out, but no matter which way I jog it, it wants to go further into the table. Sounds pretty nasty too.  The DRO shows the Z axis moving correct according to the jog wheel.
With the machine off and I manually move the Z axis, all feels normal.
X and Y jogging work fine.
So did I fry my Z stepper?  Any idea what would cause this?  The GCode is fine, I have used it a number of times on production runs.
Re: Did I fry my Z axis?
« Reply #1 on: July 20, 2010, 02:41:23 PM »
Sounds to me like your Z Axis Dir wire has come loose.
« Reply #2 on: July 20, 2010, 08:30:43 PM »
Thanks hood.  That was darn close.  It was the connector from the back of the control box, other side of the Gecko.
