Hello Guest it is October 06, 2026, 04:33:03 AM
Author Topic: Use dll in vb scripts  (Read 6934 times)
« on: July 20, 2010, 01:55:46 PM »
Example I wish to open port rs232
Code: [Select]
Private Declare Function OpenPort_PR Lib "DevicePORT" (ByVal lpPort_Name As String, ByVal dwSpeed As Long, ByRef lpHandle As Long) As Boolean
Dim hRF As Long
If OpenPort_PR ("Com1:", 115200, hRF) Then Code "(MSG, Port OPEN!)"
mach3 writes error:
Error on line 3 - Error in loading DLL
Whether it is possible to work in general with dll in vb scripts? If yes that as
It correctly to do?
